Patch (New) Untrimmed does not support internal points/curves
Four exterior sides with interior points and/or curves.
Need untrimmedsurface
New Patch: “Untrimmed does not support internal points or internal curves.”
Is this a recent change to the new Patch. I seem to remember previously being able to use the combination of untrimmed domain and internal points and curves.
The old Patch support untrimmed with internal points and curves.
I need Patch with the ability to create an untrimmed surface with four boundaries using internal points/curves, and have greater than G0 continuity on some of boundaries.
+1 from me.
@davidcockey I also hope this can come back.
In the meantime, if you need something right now, you could make an untrimmed patch without internal constraints, and use that as a starting surface for a projected patch.
RH-96743 Patch: untrimmed with internal points and curves
We are in the process of improving the untrimmed patch generation, but not everything has been wired up yet. If you want to temporarily restore the method that was available previously, run testTogglePatchUntrimmed.
RH-96743 is fixed in Rhino BETA
