Hello everyone) do not get smooth animation of magnetic lines. Tell me how to achieve smoothness, as if water is flowing
Hello @sambrari95,
Do you mean when you move the slider?
Your definition is lagging, because the Sweep2 component at the end takes 821ms to recompute! One solution could be to come up with a workflow using meshes, instead of the ruled surfaces.
However, if you export animation frames with an animated slider, the resulting animation should be smooth, even at this state.
this slider animated at 200 and 400 frames, but still the animation turned out to be jerky
