gm_user
(G Migliorelli)
January 30, 2018, 8:55am
1
If possible, can you give some hint about a failure when trying to load PlugIn4 which uses dll (Plugin3).
The same procedure in RH 5 worked fine.
You can find both RHP (Plugin4) and used DLL(PlugIn3) at the following link:
[VS 2017 solution] (https://www.dropbox.com/s/09hc9r2galpzu4z/Test%20dll.rar?dl=0 )
Thanks a lot for your support
dale
(Dale Fugier)
January 30, 2018, 10:49pm
2
Hi @gm_user ,
Attached is now I structure a solution that contains plug-in and shared DLL. Please study closely - there is a lot going on here.
SampleSharedLibrary.zip (77.3 KB)
Let me know if you have any questions.
– Dale
gm_user
(G Migliorelli)
February 6, 2018, 9:35pm
3
Hi Dale,
finally I removed a bit of stuff which dated back to the previous migration from RH4 to RH5 and adjusted stdafx.h.
Now, manual migration seems to work a treat. Your solution was of course of great help also.
Thanks a lot!
