Fade.gh (120.1 KB)
Hello all
I feel this should be easier than Im making it… Im trying to display some surfaces in grasshopper (see the example file attached above) - but instead of a solid color with the custom preview node I want the color to begin dark at the edges and get lighter towards the center, like a gradient/fade effect
Something Id like in the end is a scaled gradient - meaning the smallest surface centers should be somewhat lighter - where as the largest surfaces (with the most distance between center and edge) should have the lightest centers - so that you can see, by the color, the general area of each surface compared to each other.
Im just not sure how to approach this the right way, I thought of trying to offset the edges but that was clunky and didnt work right. Hatch maybe?
Thank you in advance
