Hi~
In my sample file, I import picture and input scale.
Because I want to change textures coordinate on the mesh which extract from object.
My first problem is I can’t see the result immediately. I need to select the object again or change viewprot to show result.
And second problem is when I run my program again, I select the same picture and set different scale, it doesn’t show result, even though I select object again. I need to change an new picture and then I can see the correct result.
But this program works fine in the Rhino5, it can see the result immediately.
TestSample.zip (142.1 KB)
