I’m having an issue with the “Pipe” / “Gaine” display setting in Rhino.
This is not the Pipe command that creates geometry. I’m referring to the display setting that shows a pipe-like mesh around a curve, without actually creating any geometry.
For example:
I draw a circle.
I select it.
I enable Pipe/Gaine in the display settings.
I set the radius to 16.
On my colleague’s computer, the pipe is displayed correctly around the circle. On my computer, nothing appears except the original curve.
We are using the same Rhino version, and I have already:
restarted my computer;
updated Rhino to the latest version;
tested the same geometry and settings.
Could this be related to a display mode setting, graphics/viewport setting, or another Rhino preference?
It would probably help if you ran the Rhino SystemInfo command and pasted the output here. You might also do the same for your colleague’s machine and compare the two.
Accelerated graphics device with 4 adapter port(s)
Secondary monitor attached to adapter port #0
Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Users\Franck\Documents\Xnurbs\Xnurbs RV8.1\XNurbsRhino8.rhp “XNurbs”
C:\Users\Franck\Documents\Formation Python\RhinoAmcPanel\bin\Debug\net48\RhinoAmcPanel.rhp “RhinoAmcPanel” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
