I can’t seem to figure out what’s happening here. Any curve that overlaps a geometry on my viewport becomes hidden on the Shaded view. Meanwhile, changing the display mode to Arctic shows another weird behavior. Curves go through Polysurfaces on Arctic view similar to a wireframe viewport.
I’ve reset all display modes to default and the issue still happens. I also tried copying the geometries to a new file and the display issue still occurs.
Hi Thomas - I do not get this effect here, but the curves do have draw order applied - it might be that ClearDrawOrder first, then, if needed, apply BringToFront etc will sort things out.
Hi Pascal, thank you for mentioning the draw order. I accidentally applied BringToFront sometime before which caused the curves to go through geometries.
ClearDrawOrder fixed the issue.
Thank you so much. I’ve been bothered by this since yesterday.
It’s worth mentioning that you get this effect also when you look through an object with custom display mode (such as a ghosted box). ClearDrawOrder doesn’t work in that case which may cause confusion and/or frustration… Hide the obstructing item and move on.
