Display error or wrong setting? Only horizontal lines are shown
Hey people,
I have a problem with displaying lines in 2D. In 3D construction I had no problems, but when I wanted to Make2D I noticed that not all lines are displayed correctly.
For example, when I draw in a square, only the horizontal lines are shown. The vertical ones are not visible. When I click the invisible lines, I can select the square, but the vertical lines are only shown as dashed lines.
I have the same problem with circles (there are two gaps) or with polylinines (again only the horizontal lines are displayed) and Make2D.
I have probably changed some settings without noticing? I can’t find a solution. Maybe someone of you has an answer?
Thanks in advance
Hi Carla - please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09492, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Evaluation, build 2020-12-08
License details: Stand-Alone
Expires on: 2021-04-07
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H114) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookPro9,2
Language: en
Intel HD Graphics 4000 OpenGL Engine (OpenGL ver:4.1 INTEL-14.7.11)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel HD Graphics 4000
Displays: Color LCD (114dpi 1x), BenQ EW2750ZL (82dpi 1x)
Graphics processors
Intel HD Graphics 4000 (1536 MB)
Color LCD (1280 x 800)
BenQ EW2750ZL (1920 x 1080 @ 60 Hz)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.1.20343.9492
Hello - your machine it quite old, it looks like - 2012 - and not a strong display card by todays standards - I am not sure if this will ever display current Rhino’s geometry properly. That said, please try drawing your square in a new file that has no 3d geometry - does that look correct?
