Display crash (OpenGL)
sorry, stupid typo. I did refer to 332.76.
for me it has been stable so far.
I am using 332.76 on Quadro 4000, on Windows 7 SR1, with dual 1920x1200 monitors and it has been rock solid.
Here are the drivers I find on Nvidia’s site. I have a GT610 card. I don’t the 332.76, should I try to install it?? Or rather reinstall one of the oldest one proposed in this list?
I see the latest drivers for a Quadro are the 334.95… They have a small note on the info page:
This driver offers performance improvements over previous driver versions, including workstation compatibility fixes.
Wonder what that means…?
–Mitch
You’ve tested 332.76, 333.11 and 334.95…?
–Mitch
I just installed Nvidia driver 333.11 for my Quadro K4000, running under Windows 8.1 pro-64 bit. I’ll update in a few days if it works any better.
In the meantime, “Save early, save often.”
No @Helvetosaur, I haven’t. I don’t have a Quadro. Jeff does and does testing from time to time. He’s currently working with the Nvidia driver people to help sort out some of these problems. For a long time they have ignored us and now it seems they have been pestered by enough Rhino users they decided to reach out.
I hope it gets sorted.
I went back to the 334.89. It does crash. I’ll try to install the 331.58 one and see if it helps.
My file is about 30Mo. I guess it’s kinda heavy. But can it be related to those crashes?
One other thing I keep seeing is the built in Nvidia tool for checking for driver updates seems to be wrong a lot of the time.
Any time I’m looking for a driver I go here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
It shows 335.23 from March 10 there now for an Nvidia GeForce GT 610 under Win7/8/8.1
It’s the last driver I’ve had installed but this one or the previous one doesn’t prevent rhino from crashing.
So I found the version 327.23 (released 2013.9.19). I will test this one. If it works, I’ll tell you, if not then I can say it’s not related to the drivers because at this time, I had never had a crash like I’m facing nowadays.
That’s what Jeff found when he tested them before and found the one that worked for Win7. That’s what prompted my comment that I was not aware of a “good” driver for Win 8/8.1 yet.
I had a lot problems with drivers of the last weeks, but at the moment 334.95 works stable for my Quadro 6000, no crashes since a few days anymore.
I enabled the workstation dynamic streaming mode, enabled max power usage at the 3D settings and set the TDR registry entries.
Did you make a profile for Rhino, or did you alter the “workstation dynamic streaming” mode?
What setting did you use?
No, I deleted the profile for Rhino and edit the global “workstation dynamic streaming” mode for max power, because I had crashes for Photoshop and other software too.
For TDR I set level 0 and delay 20.
Thanks for the info Micha!
I set the level back to 3 and delay at 10, since my computer freezed after Nivida crashes and no driver restart started. Also since I install the Quadro 6000 card I had the problem that my machine doesn’t wake up after standby some times and maybe I found a solution now - I installed a bios update and now it seems to work. At the update infos was written “fix stability problems”. So, maybe this info is helpful for other graphic crashes too.
Last I had some strong Nivida driver problems and Windows 7 automatic installed the latest driver 335.23. Works quite stable yet.
