Not sure is this question was already raised before.
Basically when I start editing block - all other objects (not belonging to blocks) are displayed in grey.
But if there are other blocks in the drawing - those are displayed with its native color!?
Hi Dmitry - I see that this is the case when the block layer is locked - is that what you see? Not that it should be this way, but If the display mode is set to show locked layers in object color, then this is used by BlockEdit. Shout if you see something different than that, and meantime,I’ll see if that can be tuned up.
