Dispatch a list to select every other row
I am new to grasshopper list and sorting, I have a simple question, I have a list of paver curves that I want to dispatch to select every other row not every other curve. I did some research about sorting it by y coordinates and using cSet, but still I didn’t get it to work.
I attached the GH file and a screenshot of how I need the dispatch to work. In the GH file there is a group called “Area of Focus” that are the paver curves I am trying to dispatch.
FYI, it may be a little heavy at first
Any help would be greatly appreciated.
Thank you
Paving Question.gh (18.3 KB)
Your Grasshopper definition is missing a few relevant inputs. Please make sure whatever is required is internalised. Right click a component and select ‘Internalise data’…
Hi @martinsiegrist
Sorry I did not check every internalized item, here the script with the internalized data.
It takes from 3 - 5 min to open
Paving Question.gh (18.9 KB)
lines.gh (24.7 KB)
Arg, Beat me to it @ftzuk
I got sidetracked after I saw this in the script.
So i replaced it with this. Should be a little simpler.
Paving Question Ryan.gh (21.6 KB)
Thank you so much for the help it works perfect!
