I have watched several videos on dealing with edges. However, I could not find anything on this problem.
I have a wing shape. The green paths define lines of constant thickness. It was created on an application that allowed lofts using guidelines. So I could loft between the frames and specify the green lines as rail guides.
Apparently, I am limited to a maximum of two rail guides on Rhino. If I divide the curve at the maximum thickness guideline and Sweep2 I get this:
I get a visible discontinuity at the edge between the two surfaces.
I’ve tried creating this in various ways with equally bad results. NetworkSrf creates a surface that bulges beyond the maximum thickness line. Doing a Sweep2 using both segments of each frame does the same.
Fillet does not seem to work in this case.
Is there some way to smooth out the edge or create a the surfaces with a continuous edge?
I’ve attached the file showing the problem area:
Problem.3dm (62.6 KB)
