Disable blocks
Is there a way to disable “blocks” on imports ? When I import dxf, dwg and step files often times I get unwanted blocks I just wind up exploding. Is there a setting somewhere to disable blocks ?
There is no such setting, no.
You could write a macro to import, select all, and explode blocks but that won’t work if you drag and drop files for import.
