Is there a way to change geometry of a directshape without losing any of it’s tags or parameters like mark, area etc.?
Element tracking ensures you don’t lose Tags or Parameters. Can you provide a example and info if this isn’t the case?
What I meant was, let’s say you placed a DirectShape in your project a month ago and it’s been released from Grasshopper. Some people have worked on it and added tags, etc. If there is a way to change only the geometry without affecting the other stuff, that would be awesome.
I am on RH7 and using latest daily build btw. If you need any file please let me know.
Direct Shape isn’t the proper workflow for that scenario, they are by definition not going to be editable.
That would require a Revit Family instead.
