Direction on multi surfaces
Do you have any trick to set the same direction on multiple surfaces? So far I use Dir command but it takes so long time.
Are these planar or nearly-planar surfaces? The following scripts might help:
Planar surfaces only:
UnifyNormalsView.py (1.3 KB)
Planar or non-planar surfaces:
UnifyNormalsViewNP.py (1.9 KB)
(results may be unpredictable if the surfaces are highly curved)
Both of these are current view (face the camera) dependent. I also have world-aligned scripts that are view-independent if you need.
Thanks a lot. It looks that you have a script for every occasion :slight_smile:
Have a nice day!!!
