Dimetric view in rhino 7
Hi
The title describes my problem. Do you know how to create a dimetric view in rhino 7?
Thanks
if i understood it correct you can start with the command Isometric that will make a parallel projection and depending on how exactly one interprets dimetric that might be already enough, since there are some different views and drawings out there describing it all a bit different you might be able to simply cmd shift the rotation (for parallel views) to achieve your exact position.
i attach a file where i have 2 named views with one dimetric and one trimetric, with the turned off wallpaper as a reference i took the perspectives from. maybe that helps.
dimetric, trimetric.3dm (3.6 MB)
Just change the word from dimetric to axonometric, and use any angle instead. :tipping_hand_man:t4:
