Dimensions now have tick marks
No big deal but my dimensions now have tick marks versus arrows…
I dont remember changing anything is why i mentioned this
Hi Jeffrey -
That’s a setting in the annotation style that you use.
Perhaps you are using a different style than the one that you used to.
I’m not sure if this is related but I came across a similar issue recently. Jeffrey - can you see the arrows when you select (i.e. click on) the dimension? I was adding dimensions to an inserted jpg drawing and found that my arrows were not visible but the rest of the dimension (lines and numbers) were visible. The workaround was to bring the dimension to front. I then tried to send the jpg to back so I didn’t have to bring every dimension to front as I was making them but found that the jpg was unaffected by the “sendtoback” (or whatever it’s called) command.
