Dimensions Fit Arrow / Fit Text Options
Hi there,
Here’s the problem: in the “Dimension” Option panel, there are these two Options “Fit arrow” and “Fit text”:
For example, by creating a new dimension, the Fit Text Value is automatically set to “HintLeft”,“HintRight” or “Auto”:
Therefore, I want it to always be set on “Inside”, but I do not find thoses parameters in the “Annotation Styles” Menu…
Does anyone have an idea?
Hi Jeff - as far as I can see so far, it is only per dimension as you point out.
Hi Pascal, thanks for your feedback.
Well, that’s also not so cool, as the dimensions have to be manually modified afterwards. A default behaviour control in the “Annotation style” menu would be nicer…
Hi Jeff - I’ve put your request on the list as RH-49911.
Hi Wim, Thank you!
