After upgrading from previous WIP version. Deleted entire application with appcleaner (throws out all related installed files in Library directories, such as Preferences, etc.) and then reinstalled. Retried using dimension but still no values. Tried tweaking dimension styles (altered font, size, color, etc.) with no change.
Dimension tool now seems broken.
Need to revert back to previous version of WIP but sadly don’t have a copy. HELP!
Reverting back to 5E12w without blowing away Preference or other .plist files resolved the problem. It doesn’t seem to be related to preferences or other settings.
Development will probably fix this in a couple of days…
i went ahead and updated to 5E44w on one of my computers and dimension are appearing correctly.
that said, i do notice a strange but non-critical difference in behavior compared to past versions… the actual dimension text doesn’t display until after making the final click in the Dim command… up to that point (during the preview) , i only see the extension lines and arrows… in previous versions, the preview also contained the text of the dimension.
