I have issue with dimensions, in layout it shows correctly but in pdf its different.
Hi @kristjan.tolk can you share a 3dm file so we can test this issue?
Hi @kristjan.tolk I got your file, thanks. But I can’t reproduce this problem. Dimensions in the PDF look like in the model. Which PDF printer are you using? can you share the printing settings?
These are mine:
Hi, i tried your settings as well, still the same problem.
