Dimension arrows
Hi, in V5 if you made a dimension that had the arrows inside the dimension lines, then moved the dimension text outside the dimension lines the arrows would flop to the outside as well. In V6 is there a way to make this happen? We are stuck with dimension arrows inside even if they barely fit.
Eric
Make a dimension and select it.
Look at the properties of the dimension in the Properties Panel.
There are controls for “Fit arrow” and “Fit text” that I believe are what you’re looking for.
Hi John, that doesn’t really get at what we are seeing here. I’ll find an example I can send in.
Eric
Perfect. Thanks
