Let me describe the image I am trying to achieve. There are two connected arcs at the top of this figure. I would like to label the longer arc as 20 degrees, indicated with the numeral 20 and the degree sign centered just above the arc – with curved dimensional arrows running to the ends of the arc. The adjacent, shorter arc is 5 degrees. I would like to label this shorter arc in the same manner.
The Help file for DimAngle suggest this type of presentation can be set up by first selecting the arc, rather than its end points, but no such luck.
DimAngle, as you can see in the jpg, has introduced enormous numbers. Enormous point sizes relative to the drawing. And an enormous interpretation of the angle – 340 degrees rather than 20 degrees.
What would be a good first step? Maybe something to downsize the monster type font?
Thank you for your insights.
Michael
