Difficulty selecting edge with shift+ctrl RHINO 8
Hi Guys , i have just upgraded to rhino 8 , im having problem selecting edges with the shift+ctrl
this is in Rhino 7
this is rhino 8 , sometimes the edge can be selected but its like 1 out of 10 times
is there some option that i did not turn on ?
Hi Micky - it looks like, maybe, the selection filter is set to Sub-Objects so Ctrl-Shift selects top level ones?
Also, is that object in a group?
Bump…
Having the same problem on chain selecting edges with ctrl+shift+double click on all object types. It work some object but not others.
Its not the selection filter. I’m running on two computers. One works fine, the laptop does not.
Rhino 8 SR18 2025-3-11 (Rhino 8, 8.18.25070.14001, Git hash:master @ d450d6adb914b46ae47a91e60cd335723789cf13)
License type: Commercial, build 2025-03-11
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-20-2023 (M-D-Y).
Primary OpenGL: NVIDIA RTX A5000 Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.35
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-13-2024
Driver Version: 31.0.15.5335
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Users\cz7b38\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\DATAKIT\Rhino8_Import_x64.rhp “Datakit_to_rhino8”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25070.14001
Hi Benjamin -
On the laptop, create a copy of the Rhino icon on the desktop. Right-click on the copy of the icon and go to Properties.
On the “Target” line, add
 /scheme=Test123
Then launch Rhino from that new icon.
Is the behavior the same when you run Rhino from this factory-default scheme?
i was unable to add
/scheme=Test123
to the target line of the shortcut
Incidentally, I had two Rhino 8 shortcuts on my desktop with two different creation dates I deleted them an made a new shortcut and it seems to work fine now.
I also copied my setting folder from the desktop computer to the the laptop before I was this reply, so I honestly cant say what resolved it.
Hi Benjamin -
Good to hear that you got this solved.
It was copying the settings from the desktop computer that solved this.
That doesn’t sound good…
You should be able to do something like this:
