Difficulty Modelling Roof of Building with no Elevation or Section
Dear users,
I am a beginner in Rhino and need to model a building to scale for my site. I have begun modelling the building and found great difficulty in modelling the intersecting roof structure and overhang. Could you please advise me on the best way to do this, I have made a generous attempt but it still looks off. Any help is appreciated. I have attached a google drive link of images of the building, the building model I’m currently working on and the co-ordinates for the site. Please let me know if this is sufficient information. Google Drive Link: Site Model - Google Drive, Co-ordinates:
It looks like you are off to a great start. Where exactly are you running into modeling issues?
Push/Pull & Solids modeling should get you there quickly.
Hi Japhy,
I’m having trouble with the intersection points of the roof, the window’s that protrude out and the two roofs that intersect the larger one. If you look at the aerial image, you’ll see that my model doesn’t really show that intersection very well, I wonder if it’s because I haven’t added any over hangs and I’m not really sure how to go about it because I’m not sure if it’s been modelled correctly. How can I create these intersections neatly as possible? Also with the windows on the side that also stick out, I was wondering if there was a simple way to draw them as I’m having trouble with these angled slopes of the roof and what tools are best to remove the excess, I’ve been using split and trim so far. Hopefully, I’ve explained it clearly here. Essentially, my main issue is the intersecting roofs and modelling overhangs.
