Diagrid on a curvy 2d surface GH
Hi guys, so I am new to GH and I was wondering how to triangulate a surface in grasshopper that is not a perfect rectangle. I wanted to create a similar effect for what the triangulate command does but with diamond shapes. The surface I wanted to apply this grid looks like this (attached). Do you guys have any tips?
PS. My problem is that when i try to use the diamond grid it turns the surface into a rectangle
Thnak you very much
hi, the surface turns into untrimmed, if the surface is planar you could use region trim, if its not with the srfClosestPts distances. see attached:
file:20171129_Diamond.gh (14.3 KB)
Not sure whether you wanted a diagrid or a tessellated surface, as they are distinctly different, tessellation will result in trimmed surfaces:
shape_surfaces.gh (21.2 KB)
thanks guys! this helped a lot!
8 months later :smiley:
You are lucky there was a thank you. I had a 4 month later with no sign of politeness…:rage:
Yeah saw it a few days ago. I’m sure in his inner he was thankful :wink:
