Hi, in Version 6 SR6 there is a small bug in setting the detail scaling. If you click in to the detail to make it active then click on the Edit Scale button in Properties, the prompts are correct but nothing changes in the end, even though Locked is unchecked.
Setting the scale by selecting the detail border works correctly.
Need to add a bug note to this thread.
There is a scaling issue with the detail scales if your paperspace units and drawing units are different. for instance if my model is in millimeters and my paper space is in inches then if I try to change the scale to 1" = 25.4mm the scale updates.
But if I switch to the layers tab and come back the scale now is different.
Seems like a unit system conversion issue as the detail doesn’t change scale during the above sequence.
