Is it possible to flip a detail item with RIR?
If I am correct, we can’t access these flips through the api… but would a mirror / rotate elements work for you ?
Yes, a Mirror & Rotate would work… Bit of a workaround… However, it would work.
Would a Plane Placement work for this? Instead of a point placement.
Hey @christopher.pires ,
So apparently the flip method in the api works with these controls, so in RiR there is a component that already does that “Flip Element”, and it works only when the family has a flip arrow in each direction (facing / hand) accordingly… also below is a rotate component if needed.
RotateElement.gh (13.7 KB)
