I’m trying to use the ‘curve to volume’ command from the Dendro plug-in.
However I get the following error everytime I try to run something from the convert section:
Solution exception:An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
Can someone please advise me how to fix this error.
I had the exact same problem, and the solution is to redownload Dendro from PackageManager in Rhino. You just have to type ‘‘ PackageManager ’’ in Rhino as an instruction.
The reason why this is happening is because the file named DendroGH. dylib is a file only for mac users, so it won’t work on windows pc. Hope this helps!
