Good morning, how can I delete all points that exceed a quota (z factor) set?
Thank you very much
Upload your .gh file.
Delete point.gh (42.6 KB)
I’ll look at it, but I assume the problem is, that you are culling out the Z values, and making the list of Z values provided to the “Construct Point” too short. You need to replace the exceeding Z values with a max Z value instead of removing them all together.
pDecon connects to the UnitZ vector determining your max Z height. You will have to increased the slider max. value (20?) to get a value that doesn’t look like just a line.
Delete point.gh (63.7 KB)
I would really need to get rid of them, because by flattening them out I then have a number of problems in that I then have to join the points together and I get a straight line
Delete point_02_tp.gh (43.4 KB)
are you searching for the dispatch component ?
use the result of smaller then as dispatch pattern.
hope this helps - kind regards -tom
