Culling Points with 2 out of 3 identical coordinates
i am trying to Delete all Points out of a point cloud with the same X and Y coordinate but the one with the highest Z coordinate.
I am a beginner and unfortunately don´t really have a clue wich components i need to combine to archieve this.
At the moment i got a list of Points that are placed on the surfaces of a brep.
Thank you in advance!
I don’t know how to delete stuff with grasshopper. It’s possible (via coding), but I don’t know how. I did manage to filter out the highest points from the lowest points, though (also via coding).
get_highest_points.gh (6.2 KB)
If you’re willing to just use a plain python script, I do know how to delete stuff via plain python (just not in the grasshopper context). You must run the python code within Rhino (Tools > Script > Run). You can also look at the code (Tools > Script > Edit). A test rhino file with some points is provided. If you run the script in a production file, please save your work before running the script (though you should be able to press ctrl-z to undo the script)
delete_lowest_points.py (1.8 KB)
point_test.3dm (44.7 KB)
Oh, and I used regular points and not point clouds (I’ve never worked with point cloud objects before).
