Delete attributes component bug
Delete attributes gives 1. Solution exception:Object reference not set to an instance of an object.
and outputs less geometry then comes to it from import dwg node. It worked before.
Hatches turned out to be the problem.
I just tested deleting attributes from a hatch object and it worked as expected on my side.
Please let me know which version of Rhino and the ShapeDiverp plugin you are using, and also attach a minimal definition showing the issue.
Shapediver 1.21.0
Rhino 8 SR11 (8.11.24254.15001, 2024-09-10)
example.dwg (356.6 KB)
example.gh (9.9 KB)
Your example works as expected on my side:
Could you try to update Rhino to SR12?
Are shapediver rhino 8 servers on sr12?
updated now it works. thanks
Yes they are, you can always check that on your ShapeDiver platform dashboard: https://www.shapediver.com/app/settings/backend
