Hi
I have a script with a delaunay mesh, openings vary with attractor points.
the attractor points are working fine, the scale works too,
The scaled geometry and the original mesh do not loft.
triangle roof.gh (46.4 KB)
triangle roof.3dm (230.0 KB)
Also if I pick single curves with item list, the loft command works, but it does not happen with the merged geometry.
triangle roof_solved.gh (33.2 KB)
You had to graft each set of curves before the merge, so each of them only loft with their corresponding pair, otherwise you are telling grasshopper to loft every curve at once, is just another step in learning how lists and threes work in GH, have fun!
