I can’t delete Dimension using Del key (Canc in italian)… I wuold like to know if someone knows why. Thanks
Hi Luca -
By default, dimensions are history-enabled. This makes them children objects from the geometry that you are dimensioning. When you have set the history options to lock the children, you won’t be able to delete them. You’ll either have to turn that option off or change the default of dimensions being history-enabled.
It works and that is so great. Thanks!
