How to perform a deformable transform of this 2D shape as opposed to sharp piched transform, ref images att
ached
deform.3dm (27.3 KB)
Flow on surface should be fine for that, use as reference and target surfaces same as your screen capture curves
Hello- I am not sure why you want to deform an existing curve rather than create one of the desired shape to begin with…?
Hi Pascal, I misunderstood, thought the idea was to insert the text into the shape
Ah - right - I was responding to the OP, not you though… sorry if that was not clear. ![]()
