I have a flat surface and a box as shown in the picture below. I want to form a new surface such that the flat surface deforms with respect to the box. (It goes down like creating an impression).
How can this be done?
Thanks
Kai
Thanks
Kai
Hi Kai -
There is very little information in your post. Provided that the red surface has normals pointing up, the BooleanDifference command would create something like that…
Hello Wim,
I want to achieve something like this. The surface has sunk or deformed because of the box.
Use Drape command.
Thanks! but I tried using drape command, but I did not get the results I was looking for. Secondly, I also want to cause the above deformation using a script.
Maybe the flat surface had too few or too many control points or wrong degree?
SoftMove command gives you more flexibility to bend the flat surface.
If the bent surface is not perfect, use SoftEditSrf command to fix it.
Hi Kai -
That should probably have been in the first sentence of your original post?
You also hadn’t categorized your post and I can move it to a different category so that the right people see this, but what kind of script are you talking about?
Hello Wim,
I am new to Rhino and the forum. C# (using RhinoCommon) or a Grasshopper script that may be helpful ? My ultimate goal is to make a plugin for it.
-kai
