Default VA objects problem!
why I have to load visualarq objects each time I open new rhino file ?
Hi @huss191998, you need to start a new document from a VisualARQ template to see all object styles. You can make it your default template. Or you can also import the .val file that contains the full library of VisualARQ object styles into your current document or into a new Rhino template, and save it as a custom template. (That .val file is located in this folder: C:\Program Files\AsuniCAD\VisualARQ 2\RHINO6\English\Libraries)
You can read more about this topic here: https://www.visualarq.com/support/tip/i-cant-see-the-library-of-visualarq-object-styles-why-how-can-i-load-them/
