Is there such a thing? Im not sure why, maybe it’s just my mouse but rotation speed in Rhino is pretty hefty in general. Sometimes it is almost impossible to get a specific view because of the speed and the “steps” in rotation. Working with really long objects I should mention haha.
Hi Eg -
It sounds like you need to make sure to place a camera target in the correct location to be able to rotate as needed.
You may also want to change your viewport projection to parallel for long objects, and check if “auto adjust camera target” is on under view options, it sometimes gets a bit eager so I tend to keep it off and just manually retarget with zoom selected (can also use this on subobjects like edges for longer objects)
That was my solution so far+ZoomSelected. A option for sensitivity would be nice though.
