Hi Guys,
I need to revive this old request. With many improvements in Rhino even since, this issue now got promoted to the “top 3” Rhino workflow nuisances over here, and seems like it could be a low hanging fruit to fix.
Let me explain a bit more why this is important and problematic:
In our work, most of the projects and modeling effort is strictly view-based. Obviously while modeling we spin the view all around as everybody else, but once the cameras / named views are set and selected, the model and scene are constantly evaluated from the given view, whether there are more problems to fix, details to add etc.
So in order to keep the camera in place while looking around and at close-ups, the view navigation is a combo of ZoomLens (Ctrl+Alt+Shift+RMB) and RotateCamera (Ctrl+Alt+RMB).
This is where the problem begins - from around Lens=300+, the RotateCamera moves way too fast, and with higher values, which is not uncommon with how we need to work to see model detail, a tiny mouse move rotates the view into the outer space…
I don’t think this is by design, I can’t imagine anyone finds this behavior useful, so hopefully a tweak to make it more intuitive would not create problems somewhere else.
I did my homework to try to figure out where the problem is. It seems like Rhino currently is measuring the screen pixel distance of the cursor movement, and multiplies it by a fixed angle to rotate camera in that direction. Which results in OK-experience in “normal” lens scenarios (10mm-200mm), and really bad experience with higher values: the higher the faster/more unusable.
What seems to work instead for an intuitive camera rotation speed regardless of the current lens value is the “adaptive” angle approach, where the camera rotates by an angle that is connecting previous and current cursor position on each cursor move (Vector: CursorA-CameraPoint remapped to Vector: CursorB-CameraPoint rotation type)
I wrote a quick scripted testing tool to compare both rotation modes, I hope you can check it out:
RotateCameraTest.rvb (3.5 KB)
[LMB-drag to rotate, SPACE toggles the mode, ESC to exit]
Here is a sample test file with NamedViews with various lenses:
RotateCameraTest.3dm (4.6 MB)
This is easier explained visually (follow the cursor movement in relationship to how much the camera rotates in both modes):
@mikko, I am guessing this may be your turf, would it be possible to fix this and implement the intuitive rotation method for the reasons mentioned above? It’s currently a struggle pretty much on every project over here.
thank you,
–jarek
