Data tree. Multiple value stream
Hello, community,
I wonder is there a way to define an expression inside value list?
If yes, how to syntax a value that output all other values of a tree?
a = branch 1
b = branch 2
c = branch 3
d = a and b and c
Maybe there is other approach than value list?
You can use the Split Tree component like this, along with a Value List containing these options:
  • a = "{*;0}"
  • b = "{*;1}"
  • c = "{*;2}"
  • d = "{*;(0 to 2)}"
Each pattern allows you to filter specific branches from the data tree.
Untitled-1
SplitTree.gh (3.5 KB)
Thank you so much!
Lastly, what is the keyword that summarize expression syntax (I hope a correct name)?
Does it relies on universal programming language fundamentals?
The syntax used in components like Split Tree is known as Path Matching Expressions. It’s similar to wildcard logic (*, ?, ranges), but not based on any standard programming language.
More details: datatree-selection-rules
thumbs up!
