Hello everybody,
I would like to start by saying that I have learned several things just by reading some other problems this community has solved.
I am still learning grasshopper so I believe my problem is about data management or list item components, I want to share an image which has a pattern that I am trying to duplicate in a random surface, the main surface has no problem doing it ( square pyramid) , my problem is when I tried to create the secondary graphic at the top of this shape, I actually created already the points where every line should go but lines are not doing what I was expecting . I tried several options already but so far nothing is working yet.
Of course I would like to add later an attractor point like image reference.
Also I have been thinking that instead of creating the shape with curves to try to deconstruct my main body and rotate it but i believe it might create some other problems
Anyways if anybody has an idea it would be great.
Thank you in advanced.!
square pyramid.gh (30.5 KB)
