Cyclops Daylight autonomy gives unexpected results
Hi Cyclops team,
Working with your plugin works quite well, but the results for daylight autonomy are unexpected. All values are in range of the same value. Which is strange because one would expect that the values close to the window are higher then deeper inside the space.
Did I do something wrong with the material properties or…?
@WojciechKarnowka
Could you please check that in de the attached file?
Many thanks in advance.
Wouter
Gebouw C.gh (75.5 KB)
Gebouw C.3dm (97.0 KB)
Hi @Wouter_Notenbomer,
Apologies for the delay. The issue in your file seems to be the visualisation. Make sure you set the lower/upper bounds of your visualisation domain to reflect the results bounds.
