How to prepare geometry for Cyclops?
Hi Cyclops Team,
I am having trouble figuring out how to prepare my Scene Object meshes. All the tutorial files work properly on my system but when I try to create an analysis of my own, for example a Point in Time Daylight Analysis, I get absurd lux values of more than 10k+. My guess would be that this is happening because the mesh might have some tiny holes that are getting missed? The profile of the building does have degree 2 curves so maybe there is some issue in the meshing step.
Here is the .gh file - how to cyclops.gh (35.2 KB)
Here is the .epw file - IND_Mumbai.430030_IWEC.epw (1.5 MB)
Hi @Kyuubimode,
A few things.
  • I would recommend that you work in meters. That is the standard unit in EPW files.
  • The analysis points are directed down towards the floor. The direction should normally be orthogonal to the surface you’re analysing, meaning upwards in this case.
  • The analysis points are placed coplanar with the floor geometry. They should be moved slightly above the floor to avoid the risk of rays intersecting with the floor.
Also I don’t believe a 10k+ lux value is absurd in direct sunlight.
how to cyclops updated.gh (33.0 KB)
Sweet, thanks a lot! Completely missed the analysis points being in the wrong direction. Thanks a lot for your help.
I forgot to say that I meant 10k+ LUX everywhere in the building as opposed to just near the windows. I was just looking at the numerical bounds of the daylight analysis result to check if the analysis was working.
