Hi all,
Is there a way to have your CutPlane be perpendicular to a planar face of a polysurface being cut, regardless of its orientation? Ideally this would be done without a custom CPlane. Maybe aligning it with surface normals?
Thank you
Hi all,
Thank you
Hi Pavel - CutPlane only works off of the Cplane - you can make a macro that handles the Cplane
! _Cplane _Object _Pause _CutPlane _Pause _Pause _Pause _CPlane _Undo
Thank you Pascal. This does the trick.
-Pavel
