I have two tubes how I can cut a tube by tube. Then can make groove bevel for Tube was cut
Untitled.3dm (178.8 KB)
Thanks
Thanks
Hi @nguyentheta2002,
I split the outer tube surfaces and inner tube surfaces separately. I created the beveled surface using a line and Sweep2
Untitled.3dm (231.1 KB)
– Dale
I created pipe cut but I don’t know how to bevel this
can you make a short tutorial
Untitled.3dm (189.4 KB)
Thanks
explode the tube and split the inner and outer surfaces separately. then loft between the two edges you created by doing this and join.
