if you would build those surfaces out of 2 continous surfaces, then you could split with option isocurve. to achieve that duplicate the 2 edges along the side and join them since they are split into several parts then use RebuildCrvNonUniform for example and sweep2 both surfaces voila
I will try it right away thanks. I did it with booleans and that is the reason why I did not get the continuous surfaces.
In this case I do not know what you mean. My " star " is intersecting in every part of the surfaces.
