Customized Shortcuts Bug - German Keyboard
Hi everyone,
I have a problem with setting customized shortcuts: Since I’m from Germany, my keyboard layout is different from the US-layout. However when setting a new shortcut Rhino uses the US-keyboard-layout as default and I can’t use these shortcuts afterwards because some of the letters just don’t exist on the german layout and vice versa.
For example: When I want to make the shortcut ‘Command + #’ Rhino makes the shortcut 'Command + ' instead, which I then can’t use.
Is there a setting I didn’t find to change that or is it a bug within Rhino?
Thanks in advance.
