Select more objects to an existing list - Rhino Common
We have a list of objects which we highlight(select in code).
We need to be able to let the user pick new objects without unselecting these objects.
The user should be able to select/unselect every object (both old and newly selected).
The selection process should end when the user presses ‘Enter’ or in a similar manner.
Do you have any suggestions how to accomplish this?
Thank you!
Hi Cristina,
I think this is what you are looking for. Let me know if it isn’t.
  var go = new GetObject();
  go.SetCommandPrompt("Select surfaces and polysurfaces");
  go.GeometryFilter = ObjectType.Surface | ObjectType.PolysrfFilter;
  go.GroupSelect = true;
  go.SubObjectSelect = false;
  go.EnableClearObjectsOnEntry(false);
  go.EnableUnselectObjectsOnExit(false);
  go.DeselectAllBeforePostSelect = false;
  var objects_were_preselected = false;
  while (true)
    go.GetMultiple(1, 0);
    if (go.CommandResult() != Result.Success)
      return go.CommandResult();
    if (go.ObjectsWerePreselected)
      objects_were_preselected = true;
      go.EnablePreSelect(false, true);
      continue;
    break;
  // TODO: process selected objects here
  RhinoApp.WriteLine("Object selected count = {0}", go.ObjectCount);
  if (objects_were_preselected)
    // Normally, pre-selected objects will remain selected, when a
    // command finishes, and post-selected objects will be unselected.
    // This this way of picking, it is possible to have a combination
    // of pre-selected and post-selected. So, to make sure everything
    // "looks the same", lets unselect everything before finishing
    // the command.
    for (var i = 0; i < go.ObjectCount; i++)
      var rhino_object = go.Object(i).Object();
      if (null != rhino_object)
        rhino_object.Select(false);
    doc.Views.Redraw();
  return Result.Success;
– Dale
Thank you very much for your help!
We managed to use your code in our method.
Thank you!
Cristina
I had more or less the same problem of @cristina.b so I updated the code posted by @dale in order to use it with Rhino 6.
These are my updates:
CRhinoCommand::result CCommandSampleSection2::RunCommand(const CRhinoCommandContext& context)
  CRhinoGetObject go;
  go.SetCommandPrompt(L"Select surfaces and polysurfaces");
  go.SetGeometryAttributeFilter(CRhinoGetObject::curve_object);
  go.EnableGroupSelect(true);
  go.EnableSubObjectSelect(false);
  go.EnableDeselectAllBeforePostSelect(false);
  bool objects_were_preselected = false;
  while (true)
    go.GetObjects(1, 0);
    if (go.CommandResult() != result::success)
    if (go.ObjectsWerePreSelected())
      continue;
    break;
  //RhinoApp.WriteLine("Object selected count = {0}", go.ObjectCount);
  int selectedObjectNumber = go.ObjectCount();
    // the command.
    for (int i = 0; i < go.ObjectCount(); i++)
      const CRhinoObject* rhino_object = go.Object(i).Object();
      if (NULL != rhino_object)
        rhino_object->Select(false);
    RhinoApp().ActiveDoc()->Redraw();
  return result::success;
Unfortunately now I’m not able to understand why, if I deselect (maybe accidentally) an objected previously selected, I can’t reselect it.
Do you have any idea about how can I solve this issue?
Thanks!
If it can be of help to someone, I solved using:
get.EnableAlreadySelectedObjectSelect(true);
Many thanks.
And for .NET peasants how would we achieve the same?
https://developer.rhino3d.com/api/rhinocommon/rhino.input.custom.getobject/alreadyselectedobjectselect
