I’m using “False Start Toggle” so i don’t run something accidentially.
when I toggle it, after the solution ends I popup a window that says “sucessful ran script”… then I want to reset the toggle to false for the next run.
I’m not using a button because it crashes randomly with no regard for the law.
is this possible?
i wish there was some meta-scripting capability so i do stuff like “set the state of component X to off”
I tried using metahopper but it doesn’t recognize this component, or even the default toggle component as far as I can tell.
You will have to write some custom script to do so.
Here Something like this:
if (on)
myString = "Toggle was press was success!";
//This is the section of the Code which Automatically turns off the Toggle
var toggle = Component.Params.Input[0].Sources[0];
((GH_BooleanToggle) toggle).Value = false;
toggle.ExpireSolution(true);
A = myString;
// <Custom additional code>
string myString = null;
// </Custom additional code>
I Haven’t had a chance to look at this. But I guess you can do it. You will have to create a component listener function at the 3rd component where the toggle has to turn off after running the solution. I’ll see if I can put up a small setup.
