Curve to Model Line Style
I am converting rhino curves into revit model lines using the “add model line” node. I am curious if I can also define the model line style as part of the code? I am having to change the line style every time I reimport the geometry.
Thank you!
Adam,
The linestyle is a parameter of the Model Line. You can use the Inspect component to get all parameters by right clicking or using Shift+Click to expand, Cntl+Click to get rid of unused (or right click to hide unused)
