Hi All,
It would be possible to set other default values for “convert curves to pipe meshes”?
nothing? it is impossible to do this?
as far as I understand, this topic is about render mesh modifier:
you can set a macro with the wanted properties.
the macro will start with
-_properties _curvePiping
thanks @Tom_P
then via macro ![]()
the initial part for the indicated macro works well
while for these options using the commands with
_ underscore returns unknown command
(language from it-it to en-us)
rs.Command(“-_properties _curvePiping _captype _flat”, False) <not work “_flat”>
Hi -
How about
-_Properties _CurvePiping _CapType=Flat _EnterEnd
Hi @wim
already tried as shown but it doesn’t work.
I could be wrong, but from the functioning found in the latest Rh8 update the correct syntax in Italian is this:
rs.Command("-_properties _curvePiping _captype nessuno", False)
OR
rs.Command("-_properties _curvePiping _captype piatto", False)
in these two cases both work, even just the part involved in Italian, without the need for an underscore.
but if I change the values by putting flat / _flat or _CapType=Flat / _CapType=_Flat none of this works.
(Maybe everything works fine with the English version.)
